OP, have the system pressure tested at the dealer.
I've had 2 water pumps replaced due to leaks. First leak was leaving puddles, however the second was NOT. I was slowly losing coolant.
That said, I'm still slowly losing coolant. Over 12k miles I'd be down 2-4 cups, maybe. Who knows - I've had the system pressure tested twice after the second pump and continued coolant loss, and both times no pressure loss was detected. This was at the same dealer that had no problem detecting pressure loss due to a very slow leak to warrant 2nd water pump replacement. So who knows, they are most likely being honest.
