Swordsmith
242hp/252 ft-lbs BNR EFI
Some months back I installed the VT modified turbo, and hit a snag. Although I was registering more power than before the install, I was not getting all the power theoretically available. After looking at the logs, VT said it looked like the problem was valve float; the springs were simply not strong enough to work at these power levels. We capped the tune so it would only try to produce the power the valves were limiting me to, and left it at that until the next step could go forward.
Well it looks like the springs are now available, and I have a set on order.
They have ~27% higher seat pressure (56.6 lbs vs 44.5 lbs stock) and ~29% higher pressure at open (101.6 lbs vs 78.5 lbs stock). These are not too aggressive and should solve the float issue at boost pressures up to ~28+ psi at stock redline, or lower boost at higher redline).
