Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Engine > 1.4L Turbo Sonic Engine Discussion
Like Tree2Likes
Reply
Old 10-12-2017, 01:27 PM   #21
Senior Member
Blue Moon Sonic's Avatar
Garage
Default
Quote:
Originally Posted by ChrisJ View Post
Funny you mention that.
I tried Moog's swaybar links and they failed much faster than the improved OEM plastic ones. I'm now back on a new set of OEM's. The Moog's are crap in my opinion.
That's actually really weird. Must've gotten a bad set. They are definitely not perfect. Though, I'll still take increased turn in response from the moogs vs. the oem.
__________________
In soviet russia, you don't choose the car you want to drive. The car chooses the driver.
12 chevy sonic 1.4T ltz - Back to Daily status.
2008 Ford Mustang: Engine Swapped from a v6 Building for Pikes Peak in 3-4years. Need more funds and sponsors.
2006 AWD Pontiac Vibe - Retired for emergency use only. LS swap planned.
2012 VW Golf R 6spd manual -Stage 1. In storage till new tires go on.
Blue Moon Sonic is online now   Reply With Quote
Old 10-12-2017, 01:48 PM   #22
Garage
Default
Quote:
Originally Posted by Blue Moon Sonic View Post
The BNR WGA keeps the p0299 from coming back, but requires a tune.
Is the p0299 code bad or is it okay to have on? I am going to start getting stuff done but will probably go a year between getting the WGA or just getting the upgraded Turbo. Will it be bad if that code comes on and I ignore it?
Thanks!
Crumbi is offline   Reply With Quote
Old 10-12-2017, 06:00 PM   #23
Senior Member
Garage
Default
Quote:
Thanks!
The code you are getting is an under boost code and throws the car into limp mode. The code is bad. Like really bad. You need to replace your wastegate before you cause further damage to your turbo or worse, your engine.
__________________
Reply
Tags
chevrolet customer care
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
