CAMARO-TECH
Been trying to gather info about this. Stock 1.4T uses 24LBS injectors while all I see is people upgrading to 42LBS. What is the advantage of this? HP/TRQ gain, fuel economy...? Obviously not on a stock vehicle.
Injectors are purely a supporting mod. If you want to tune and do a bunch of bolt on's, you will have to upgrade your injectors because the stock injectors will not be able to flow enough fuel. There is no HP gains and no increase in fuel economy.
I still believe I never got a true response to this post. I would like to know why people do this mod and what is the advantage of it across the board. I was a GM technician so I do know my stuff. Still no answer if helps with MPG or anything else. I got a tune but if anyone has a fuel graph to prove this upgrade is worth it please post. I just don't know this engine enough. I been running the Trifecta tune and really want to know if this upgrade is truly worth wild. Don't know the limits of the 24LBs on this engine.
