Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Engine > 1.4L Turbo Sonic Engine Discussion
Reply
Old 11-14-2017, 05:57 AM   #1
Junior Member
Default Only blows heat when on accelerator
So it's rapidly approaching winter time here in the midwest (yay..) and I'm starting to notice this year that my remote start isn't really warming up the car like it did last winter - and when I get to a stop light it will immediately switch from heat to cool air blowing from the vents. I had an issue with the coolant a few months ago bubbling/boiling out and I'm wondering if I didn't actually add enough (but I think I did.)
Any suggestions on what could be causing this? And how I can go about fixing it before the first snowfall..
Thanks, as always!
andrewcweaver is offline   Reply With Quote
Old 11-14-2017, 06:48 AM   #2
Senior Member
SuperFudd's Avatar
Garage
Default
Your coolant level may be low.
__________________
2013 Blue Topaz Metallic 1.8L Automatic LT sedan.
My wife? Yes. My dog? Maybe. My Sonic? NEVER!
SuperFudd is offline   Reply With Quote
Old 11-14-2017, 11:39 AM   #3
Senior Member
JTee2017's Avatar
Garage
Default
Thanks, as always!
First . . . the engine is probably low on coolant if you have these symptoms. Means there is air in your coolant and probably in the engine. This can and will cause the cylinder head to warp and leak requiring expensive repairs. it may already be too late.
Um . . if coolant was " bubbling and boiling out " (Where ?), there was likely a coolant leak. The plastic tank, thermostat and it's housing, water pump and various hoses have been known to leak on these engines as they age .. . .. sometimes after even a year or so.
Check the bottom of your coolant tank for hairline cracks and evidence of coolant leaking below other external coolant parts and hoses.
JTee2017 is offline   Reply With Quote
Old 11-14-2017, 05:20 PM   #4
Junior Member
Default
After I got the oil change done last, the cap from the reservoir tank came off. I believe they attempted to top off the fluid and didnít put the cap on all the way.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
