So my TC light flickers at random when at highway speed. Also noticed a oil leak from passenger side. Looks to be at the pipe right under the can cover front passenger side. Related?
Oil leaks on the passenger side of the engine can come from either the cam phasing actuator seals, the cam cover itself, timing cover, or the crank pulley seal (this tends to sling oil around). Another remote possibility is a loose/missing bolt on the waterpump as I hear those thread through the timing cover.
