2014 Blue RS
Towed the car home with the following condition:
CEL flashing and traction control light on. Running rough and smoking. I was able to get it into my garage but the next day the battery was dead.
Replaced the valve cover gasket with a new OEM one. Thinking PCV.
Checked bypass mod plugs. Good but changed one just in case.
Jump started the car. No change..
The smoking concerns me more than anything else. Pics below for things I noticed that may or may not be relevant.
Turbo oil inlet tube. Def got oil all over it. Drips on the ground.
The water neck could be an issue but one of my lines had a slight leak.
Intercooler pipe on drivers side has oil around the sensor?
Bad LS7 coil. Not that old but hey who knows.
Followed the torque pattern
Appreciate any suggestions.
