Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Engine > 1.4L Turbo Sonic Engine Discussion
Like Tree2Likes
  • 2 Post By Swordsmith
Reply
Old 04-23-2013, 03:16 AM   #1
nessquid89's Avatar
Garage
Default ZZP or DDM air intake
cant decided between them and if i go with the ZZP how do i remove the reducer after the MAF reading is right help
__________________
2013 RS 1.4L turbo manual trans
nessquid89 is offline   Reply With Quote
Old 04-23-2013, 04:18 AM   #2
Junior Member
rdss's Avatar
Garage
Default
Good luck.
__________________
2016 Ford F-250 4x4 Power Stroke
rdss Sonic build thread
rdss is offline   Reply With Quote
Old 04-23-2013, 04:40 AM   #3
RSTURBO's Avatar
Garage
Default
Im new to the forum but have done this research myself. The DDM intake is currently backordered a few weeks so thats not an option if your ready to order. Ive seen good feedback on the ZZP intake and am told you will need a tune to remove the screen which is the route im currently taking
RSTURBO is offline   Reply With Quote
Old 04-23-2013, 04:56 AM   #4
Junior Member
rdss's Avatar
Garage
Default
It's not a "screen", it's a sleeve that slip fits into the pipe to reduce the inner pipe diameter so that the MAF is still metering the same amount of air passing by it.
__________________
Old 04-23-2013, 05:42 AM   #5
DRLA3186's Avatar
Garage
Default
You can't go wrong with either, as stated the DDM one is on back order. I like the addition to get the heat shield that comes with the DDM set up, thats what swayed me to choose them.
-Daniel
__________________
2013 Sonic LT Hatchback
1.4 Turbo w/6-Speed MT
"Got Boost?"
DRLA3186 is offline   Reply With Quote
Old 04-23-2013, 12:43 PM   #6
242hp/252 ft-lbs BNR EFI
Swordsmith's Avatar
Garage
Default
You don't need to get the MAF reading right before removing the sleeve, the sleeve is there to get the MAF reading right so your stock tune will accept the intake as correct. With a tune you can remove the sleeve, increasing air flow to the design limits of the new intake.
Think of it as buying a shoe that's too big for your foot, but which comes with very thick socks that allow your foot to fit. Get a tune, like ingesting human growth hormones to make you a couple inches taller and suddenly your foot fits the shoe without the special thick sock.
Yep, Trifecta, the Roids of the Sonic. But in a good way!
Beastlick and Insanika like this.
Swordsmith is offline   Reply With Quote
Old 04-23-2013, 04:04 PM   #7
Senior Member
Beastlick's Avatar
Garage
Default
great metaphor!
__________________
Beastlick Design
- Custom grilles
- Window vents
- Headlight retrofits
Instagram: Beastlick
Beastlick is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
