Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Engine > 1.8L Sonic Engine Discussion
Like Tree8Likes
Reply
Old 03-30-2017, 01:09 PM   #11
ThatDieselGuy's Avatar
Default
Quote:
Originally Posted by Gobinator98 View Post
My car has 103,7XX miles on it.
Have you flushed it before? IIRC its every 7,500 miles for a flush or every 4-5 years.
__________________
2012 Sonic Hatchback 1.8L 170,000 miles and counting - tint, audio system, DDM Works intake, lowered w/Eibach springs and wheels&tires for now
2005 F250 6.0L Whole bunch of goodies on this one
"Anything broken is nothing a checkbook can't fix"
ThatDieselGuy is offline   Reply With Quote
Old 03-30-2017, 02:21 PM   #12
Garage
Default
Quote:
I don't think the previous owner ever flushed the coolant before. I honestly don't know what maintenance was done to the car before I bought it back in November of last year.
Gobinator98 is online now   Reply With Quote
Old 04-04-2017, 01:32 PM   #13
Default
Ahh that sucks, I am currently having to go through that on my truck and iron out all the small problems from the lack of maintenance from the previous owner lol and there is no time like the present to start catching up on maintenance (money allowing of course lol)
Gobinator98 likes this.
__________________
Old 05-02-2017, 02:28 AM   #14
Senior Member
Smartdave's Avatar
Default
Well I just took my reservoir off and flushed it. Full of oily sludge. I also notice oil dripping in the exhaust flange. It's definitely coming from the housing and not the valve cover gasket or the oil filter cap. I smelled it this evening.
I will take off the heat shield this weekend and take a look
Sent from my iPhone using Tapatalk Pro
Smartdave is online now   Reply With Quote
Old 05-02-2017, 04:03 AM   #15
Senior Member
Smartdave's Avatar
Default
Just to add, my reservoir saw completely full of light brown sludge, when I took off the lines to the reservoir those were also completely lined with the same sludge. I just ordered a new oil cooler as well as new inlet and outlet lines. Hopefully the parts will be in by the weekend. I will update this thread as to how I make out.
Old 05-06-2017, 08:57 PM   #16
Senior Member
Smartdave's Avatar
Default
Ok oil cooler changed
It's pretty simple. It's right behind the exhaust manifold.
Steps:
First remove heat shield. (Pita).
The loosen all exhaust manifold nuts (10mm)
Unplug O2 sensor
Remove 3 1/2 nuts holding exhaust pipe to cat. (Cat is part of exhaust manifold)
Remove two 3/8 head bolts holding cat to engine, underneath by flange.
Remove dipstick tube, it's an o ring that holds it in. Drain oil first before removing dip stick
Remove exhaust manifold. I also removed both engine hoist points (12mm head)
Once manifold is removed you can see the oil cooler. Remove 4 t-30 screws from the tubes, one at waterpump and one at thermostat housing.
Remove 5 3/8 bolts from cooler and slide off last tube leaving it in place.
You do not need to buy new tubes but... get all new seals from the dealer. Like $10 in total
Make sure rubber seals come off with cooler
Then clean everything
Then replace cooler
Re attach tube to water pump and thermostat housing
Install manifold.
Bolt up flange.
Re attach o2
Add coolant and oil
While everything was apart I cleaned all threads with a tap and die
Everything was put back together with anti seize
All in all I had zero frozen nuts or bolts and took about 2.5 hours to change everything over
Hope this helps
Old 05-08-2017, 03:08 AM   #17
Senior Member
RMinNJ's Avatar
Garage
Default
How cool can it make the oil if they located behind the exhaust manifold and under the heat shield ?
RMinNJ is online now   Reply With Quote
Old 05-09-2017, 01:28 AM   #18
Senior Member
Smartdave's Avatar
Default
Who knows. I think it's kind of a poor design myself
Old 05-15-2017, 10:49 PM   #19
Senior Member
Smartdave's Avatar
Default
Just a 300 mile update. Coolant is clean as can be. No more sludge or anything in the coolant tank
lambertsonic and tomas7mm like this.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
