Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Engine > 1.8L Sonic Engine Discussion
Reply
Old 10-12-2017, 04:00 AM   #11
Default
If you're going that route, recommended spec is DexronVI
skurtov is offline   Reply With Quote
Old 10-12-2017, 03:57 PM   #12
TurtleOverlord's Avatar
Garage
Default
Also if you dont have something to read temp, it takes a while to get to the required temp for checking level.
I can only hit 180 after a long drive
__________________
2015 Sonic LS Hatch
1.8 Auto
TurtleOverlord is offline   Reply With Quote
Old 10-12-2017, 03:58 PM   #13
Junior Member
ronstilson's Avatar
Default
What do you use to check temp?
ronstilson is offline   Reply With Quote
Old 10-12-2017, 04:04 PM   #14
Garage
Default
I just got an ultragauge
scan gauge, obdII bluetooth reader with torque app all work too
on the cruze forum they said you can use an infared thermometer...
but that is probably less accurate and harder
__________________
2015 Sonic LS Hatch
1.8 Auto
Old 10-16-2017, 02:17 PM   #15
Senior Member
Default
Quote:
Originally Posted by ronstilson View Post
So my trans seems to be shifting a little hard from second to third. Itís not really jerking hard itís just kind of hesitant in between gears and it does shift a little hard is that normal for them or is there something I can do to help
There have also been several TCM program updates over time for the 6 speed auto transmission. Mine has been done a few times, mostly for hard downshifting.
Something to also look at to make sure you have the updated configuration installed.
Ponchoguy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
