Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Engine > 1.8L Sonic Engine Discussion
Like Tree9Likes
Reply
Old 11-01-2017, 08:42 PM   #1
Junior Member
Onslow's Avatar
Default Water outlet estimate question - coolant leak
Took vehicle in to dealer to have check engine light looked at (sorry I don't have the exact code). Also slow coolant loss.
Diagnosis was that the water outlet (which I assume feeds the surge tank) needed to be replaced.
The part is apparently $20-$50. Dealer estimate to replace is mid $300.
Is this fair estimate for the work involved or am I just experiencing sticker shock?
Onslow is offline   Reply With Quote
Old 11-01-2017, 08:45 PM   #2
Senior Member
Smartdave's Avatar
Do you mean the thermostat housing?
The only thing that feeds the overflow tank is the radiator.
The thermostat housing is a common leak point in the 1.8.
It is a 10 minute change to replace it. You unclip the radiator hose from the nipple, you disconnect the water temp sensor, remove four bolts. Once you do that the part is off, then reverse with the new part.
Once the new part is on replace whatever coolant was lost.
On a difficulty of 1 to 5 with five being the hardest I would rate this a 1
Sent from my iPhone using Tapatalk Pro
rojoes likes this.
Smartdave is online now   Reply With Quote
Old 11-01-2017, 10:22 PM   #3
Senior Member
Papasonic's Avatar
Garage
Default
That's about $200.00 more than I would expect. Look up the part on GM parts direct, or Rock Auto. Then either purchase from them or enter the part number on Amazon to find a fair price. As Smartdave says; level 1 degree of difficulty. I wouldn't be surprised if total cost would be under $60.00.
__________________
2012 Sonic LTZ 1.4 Hatch 6-sp. manual
2017 Malibu LT 1.5 - Leather - Pepperdust Metallic
2016 Equinox 3.6 LTZ - AWD
2009 Silverado 5.3 LT 4x4 ext. cab
2004 Pontiac GTO 5.7 LS1 6-sp. manual
Papasonic is online now   Reply With Quote
Old 11-03-2017, 09:35 PM   #4
Junior Member
allstarchris's Avatar
Garage
Default
ahhhhhh niceeee
allstarchris is offline   Reply With Quote
Old 11-08-2017, 12:35 PM   #5
Senior Member
Mad*Max's Avatar
Default
Do you have the part number Dave?
__________________
2012 Sonic Orange Hatchback 1.8L
Mad*Max is online now   Reply With Quote
Old 11-08-2017, 12:38 PM   #6
Senior Member
Smartdave's Avatar
Default
This is it
https://www.amazon.com/dp/B014873JDA..._KPVaAb113AQ67
Mad*Max likes this.
Old 11-08-2017, 05:22 PM   #7
Senior Member
JTee2017's Avatar
Garage
Default
Quote:
Or . . buy one of these which are half or ALL metal and never worry about it again.
https://www.amazon.com/OKAY-MOTOR-Th...DG47F45EGJTAX4
https://www.amazon.com/Thermostat-Ho...BMEQMAKGFAX4V3
https://www.amazon.com/dp/B01NCJ9MGW...=1A589GY9FJELD
carsNskis and Mad*Max like this.
JTee2017 is offline   Reply With Quote
Old 11-08-2017, 11:48 PM   #8
Senior Member
Mad*Max's Avatar
Default
Thanks guys!
This is it
Quote:
Originally Posted by JTee2017 View Post
__________________
Old 12-11-2017, 03:18 PM   #9
Senior Member
Thesoccerone7's Avatar
Garage
Default
This was the exact scenario I was looking for an answer to. Dealer estimated $200, but said they reduced the price because they already charged me a diagnostic charge on it. They called it a "Coolant Outlet Housing" for $44 and said good luck finding it anywhere else. I have not found that part by their exact wording anywhere. Sounds like this is the part they explained. Anybody have confirmation on this? The picture is the general location the dealer pointed out to me.
__________________
Thesoccerone7 is offline   Reply With Quote
Old 12-13-2017, 01:28 AM   #10
Senior Member
Mad*Max's Avatar
Default
This is what my leak looks like:
Water outlet estimate question - coolant leak-img-20171112-00029.jpg   Water outlet estimate question - coolant leak-img-20171112-00028.jpg
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
