Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Engine > 1.8L Sonic Engine Discussion
Like Tree4Likes
Reply
Old 01-28-2018, 10:56 PM   #11
Junior Member
Garage
Default
Hi all,
I am having the same code P0171 and CEL on as well. I changed the purge valve, but the CEL came back on after changing the purge valve and clearing the codes. I checked the air intake tube for cracks, and everything seems fine. The chevy dealership also checked and they could not determine the reason for the codes. Any ideas?
jdchin87 is offline   Reply With Quote
Old 01-29-2018, 12:19 AM   #12
Senior Member
JTee2017's Avatar
Garage
Default
Quote:
Originally Posted by jdchin87 View Post
Hi all,
Did you also get the P0496 Evaporative Emission System High Purge Flow ?
The P0171 will come up for a variety of issues. It is a bit of a "catch all" code.
Maybe check some of these YouTubes. . .
https://www.youtube.com/watch?v=yGAZkrA49eI
jdchin87 likes this.
__________________
2017 Sonic * Red Rampage * 1.8L auto, LED Headlights-Back-up Lights & Interior, Belly pan, Bridgestone Turanza Serenity Plus tires, LSD Hood Struts
http://www.sonicownersforum.com/forum/image.php?type=sigpic&userid=21919&dateline=151400  3496
JTee2017 is offline   Reply With Quote
Old 02-02-2018, 11:04 PM   #13
Junior Member
Garage
Default
seems like it's neither of those parts causing the issue. have the new purge valve installed and intake tubing. still have the CEL and P0171. It's hard to determine the root cause like you said.
Old 02-12-2018, 05:04 PM   #14
Senior Member
rojoes's Avatar
Default
Valve Cover Integral PCV Valve can also be suspect.
https://www.youtube.com/watch?v=vogDBhnl6Rs
rojoes is online now   Reply With Quote
Old 02-12-2018, 05:19 PM   #15
Senior Member
JTee2017's Avatar
Garage
Default
That may be an issue, though mostly only on the 1.4L engine. This thread was related to the 1.8L engine.
__________________
Old 02-12-2018, 08:39 PM   #16
Senior Member
rojoes's Avatar
Default
Identical type of PVC in 1.8 also. I just posted that because it had good detail on how to check it for failure.
Old 02-12-2018, 08:57 PM   #17
Senior Member
JTee2017's Avatar
Garage
Default
I would say similar, but not identical. And the PCV fail has been much more chronic on the 1.4L. The rubber diaphragm often cracks and leaks. Plus, is on opposite side of the valve cover compared to the 1.8L.
But, yes, if the 1.8L did have a similar fail it would likely give a P0171 code as well. Actually, many things that can cause a vacuum leak will give that code.
__________________
Old 02-13-2018, 12:18 AM   #18
Senior Member
rojoes's Avatar
Default
Everyone I know that owns a 1.4 or 1.8 before 75,000 has had failure...Too bad they use that integral design
Old 02-13-2018, 02:21 AM   #19
Senior Member
JTee2017's Avatar
Garage
Default
Hmmm. . . daughter has a 2014 1.8L with auto she bought new in July 2014 and now 76,000 miles. So far no PCV issue. Just the purge valve solenoid, and two other of the usual Sonic issues.
Also, another member here with over 100,000 miles and no mention of the PCV.
Also, I do not believe the 1.8L had the problematic "check valve" that causes the 1.4L turbo PCV fails. The 1.8L has an entirely different valve cover design.
Every search on Google for Sonic PCV problems seems come up with the 1.4L last I checked.
https://www.google.com/search?q=Chev...w=1152&bih=606
__________________
Old 02-14-2018, 02:32 AM   #20
Senior Member
Smartdave's Avatar
Default
I have 168k on my 2012 1.8 and have not had a PCV issue
Sent from my iPhone using Tapatalk Pro
JTee2017 likes this.
Smartdave is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
