Sonic Shane
So I've got a 2013 sedan 1.8l auto. I've done quite a bit of fixing to it over the life of the car. It's got 170,000 miles. Air intake boot, fuel purge valve, thermostat and housing, I've also had an issue with the fuse box connector not making contact with an outgoing wire to the fan, that one took a while to find and taking apart the fuse box. So I had the fan stuck on and no start so I pulled a p0128 code. Easy enough replace thermostat. Replaced the whole housing do to having a lifetime warranty on it. Then reassembled. Read codes again I have three permanent codes now. p0102,p0598. And it keeps bringing up pending codes the same. I'm at a loss now. The 102 and 598 are low output voltage. I'm thinking maybe a bad connector. What do you guys think? I haven't started looking at an engine schematic to see what or how the maf and thermostat are tied together. Also only sometimes after I clear the pendings and try to start it cranks and fires then dies. I can hit the throttle pedal and it will stay running all by itself. Car runs and drives fine. Thanks
