Thermostat is on the back of the engine and the water pump is on the front. You can see the thermostat above the oil filter housing.
where's the thermostat compared to the water pump. Mine's at the dealership today for a few drops of coolant on the driveway, coming from the belt area...I'm assuming water pump, but is the thermostat anywhere on that side?
Our cooling systems must be "bullet proof". That would explain why GM has decided there is no reason to include a coolant temperature gauge in our Sonics.
Are you serious, along with other damages, the dealer's service staff actually told you this?It leaked coolent all over the passenger floor. They just replaced it and didn't replace the carpet. Said it was made to absorb moisture.
