Stratton_Chevrolet_Sonic
HOONIGAN
Hello just installed the m32 MTech short throw shift arm from BadNewsRacing! Install took me about an hour and a half. I first removed the ECM from the side of the battery with 10mm socket. Now the space to work with is tight so expect some arm scrapes. The shift cables just pop off the shift arm. The hardest part is removing the factory cap on the arm to get to the retaining nut. You have to drill a hole to be able to pry it out. I ultimately used a large punch to get it pryed out. Then use a 13mm socket to take the nut off. To remove the arm you need to pry up on it a good amount as well. Then install is simple just apply some sort of grease or lube on the splines and slide it on and reinstall cables.
It works really well throws are noticeably shorter and even a bit stiffer feeling. It's noticeable even to the eye that the shifter moves less distance.
Thanks to Jerry at BNR!
