Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Technical > Build Threads
Like Tree53Likes
Reply
Old 04-27-2017, 06:55 PM   #51
Mzooski44's Avatar
Default
Quote:
Originally Posted by mja View Post
Not a Sonic, but I picked up a '92 Isuzu pickup last week:
Super cheap, 300,000 miles, the thing runs like a top I can't believe it. A/C blows cold and heater core works. This will be my parts hauler and work truck.
4ZD1 gas Isuzu 2.3L motor, 2 barrel carb, MSG-5 speed mechanical clutch, 4.10 7.5" GM corporate rear.
I've been searching for an ultra-rare Borg Warner NWC T5 that came bolted up to an Isuzu 1.9L gas motor in '82-'84 S10/S15 trucks. I plan to swap it in the Isuzu truck (or use the Isuzu bellhousing/input shaft) to get rid of the Isuzu MSG trans for good, but parts are hard to come by.
My buddy used to drive a Red Dragon just like this. Yours is much nicer though!
Mzooski44 is offline   Reply With Quote
Old 05-16-2017, 02:52 PM   #52
mja
Senior Member
mja's Avatar
Garage
Default
Quote:
Originally Posted by Mrblanche View Post
Another one you probably can't find, but may be the same transmission, is the 5-speed that came in 1982-1985 (maybe only 1984) Camaros and Firebirds that were equipped with the Iron Duke 4-cylinder. I would bet that was the same setup in the S10.
Upon further checking, it looks like it only had a 4-speed. I would have sworn our 1984 Firebird had the 5-speed.
I wonder what transmissions they used? I've put the Isuzu transmission on the back burner, changed the oil and adjusted the clutch and it runs better, just need to put a new clutch in the old girl.
I had an iron duke camaro for a few weeks, a paint and sell deal a long time ago, that had a 4 speed auto (2004r?). I think those were rare too in the mid 80's with the 4 cyl.
__________________
2012 Sonic HB LT, 1.4T 6MT
The build thread
mja is online now   Reply With Quote
Old 05-16-2017, 02:52 PM   #53
mja
Senior Member
mja's Avatar
Garage
Default
Quote:
Thank you! I showed the best side of the truck so it looks nicer
Mzooski44 likes this.
__________________
The build thread
Old 05-16-2017, 02:56 PM   #54
mja
Senior Member
mja's Avatar
Garage
Default
GM Korea power folding mirrors:
They come stock with white caps, so I put some plastic primer on them and sprayed em black:
Next I'll add on the chrome caps.
__________________
The build thread
Old 05-16-2017, 05:40 PM   #55
Garage
Default
Do you have part numbers or links to where you bought all your stuff? Could you do a write up on it?
__________________
2017 Sonic Premier 6MT - Red Hot
Mods:
BNR EFILive Tune
Cruze Washer Nozzles
TTR Lower Transmission Mount
TTR Upper Engine Mount
Calorim is offline   Reply With Quote
Old 05-16-2017, 06:10 PM   #56
mja
Senior Member
mja's Avatar
Garage
Default
Quote:
GM Korea OEM mirrors:
PN's 95369909, 95369908
GM power mirror control switch, with folding option:
PN 95028588
Generic chrome caps for Korean Aveo mirror:
UPC 8806391567342
Just replace the stock mirrors with these ones, and put the new switch in place of the old one - wiring is a little tight with the new switch under the door panel, but it works. This gives the power folding option, all the wiring is there stock, no need to update anything.
To wire up the LED turn signals, you'll have to splice or add a wire from the turn signal circuit to the unused wire on the stock power mirror connector... haven't got to that yet.
Edit, link to Andrew's writeup for this mod:
RPO DLR Power-Folding/Turn Signal Outside Rearview Mirror Install
Calorim likes this.
__________________
The build thread
Old 05-17-2017, 12:43 PM   #57
mja
Senior Member
mja's Avatar
Garage
Default
__________________
The build thread
Old 05-17-2017, 12:50 PM   #58
mja
Senior Member
mja's Avatar
Garage
Default
VLED SMZ LED's, 25w 5k, stock fog housings
HID's
SMZ fogs + HID's
HID's + PIAA 3500k? high beam halogens
__________________
The build thread
Old 05-18-2017, 02:52 AM   #59
mja
Senior Member
mja's Avatar
Garage
Default
Starting to make an ABS fuse cutoff switch
30 amp fuse on hot side of wire
The test run works great, the switch controls immediate on/off of ABS computer circuit.
__________________
The build thread
Old 05-19-2017, 03:03 AM   #60
mja
Senior Member
mja's Avatar
Garage
Default
Switch on
Switch off
so far so good
Edit: After a few days of the ABS switch - doesn't work anymore. 'off' still cuts the ABS, but 'on' sets an ABS light now. After putting back fuse, and ECU reset, no issues.
__________________
The build thread
Last edited by mja; 05-20-2017 at 10:48 PM. Reason: How not to make an ABS cutoff switch
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
