Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Technical > Build Threads
Like Tree7Likes
  • 3 Post By 4Flattires
  • 1 Post By 4Flattires
Reply
Old 07-30-2017, 07:50 PM   #1
Default 4Flattires Street Modified RS Build
Took the plunge with the 2013 RS Hatch for autocross. Roughly $3,500 in new parts included:
1. WaveTrac
2. Chevy Performance Clutch
3. ZZP Lower Control Arms (heim joints instead of rubber bush)
4. ZZP Lower Transmission Mount
5. Eibach Pro Spring Kit with all new OEM RS Struts
6. Hawk HP+ Front Pads with Centric Rotors from Tire Rack
7. New OEM rear Rotors and Pads
8. Ported the Intake while at it
9. Requested Update to BNR Tune 15 days ago, no file yet.
10. Formerly ZZP Rear Anti-Sway Bar
11. RE-71Rs on Purple Assetto Gara Wheels from Tire Rack (225/50/16)
Firstly my thanks to Preloader's legacy. His build threads were inspirational. Others of us too. Also, the mechanic at my new job who pressed the new carrier bearings onto the Wavetrac. BTW, one of Chevy's best parts counter ladies could not ID the part number. FYI, the carrier bearings are as follows:
[IMG][/IMG]
That said, this took me three weeks to complete and more money than I expected. I'll be lucky to keep my marriage of 32 years intact now. "You love your care more than me!" To the good side of the ledger, I now finally own a complete set of metric sockets and wrenches and some other things. Did you all know that a Duralast shop crane is only $200? Well worth it.
A couple of tips to share:
1. This is was a sucky project for a mechanic who is well above average but slower than any other decent mechanic.
2. When it is time to re-install the transmission, hold the motor using a floor jack and use your shop crane and a sling to marry the transmission back to it.
3. You will want to make or buy clutch disc alignment tool for when you install the new clutch.
4. Rear disc breaks require a 2-prong socket-thing to rotate the piston while you apply clamping force. Made mine from an old socket and my bench grinder.
5. You will need Locktite 515 or 518 to re-make the flange seal between the transmission and the differential carrier cover.
Was all this worth it? My wife is skeptical. Next weekend is the Hoosier Challenge SCCA meet at Grissom AFB. I'll let you all know. I sure hope Jerry at BNR sends me and updated tune before then. A few pics are posted below.
[IMG][/IMG] Getting ring gear off the old diff.
[IMG][/IMG] Hole in trans where diff goes.
[IMG][/IMG] Replaced the hydraulic throwout bearing.
[IMG][/IMG] OEM 2013 clutch disc compared with Chevy Performance clutch disc. Larger diameter and thicker of course because it does not yet have 110,000 miles.
[IMG][/IMG] New LCAs with heim joints instead of rear rubber bush.
[IMG][/IMG] Profile view with Eibach Pro lowering kit. The new bump stops are made in Germany.
[IMG][/IMG]2 Degrees negative camber.
[IMG][/IMG] Small battery saves 23 pounds from high in the front end.
[IMG][/IMG]I have worn out one set of these. They are awesome. Best street tire their is right now.
Oops. Now I need to re-learn how to insert the pics. Can somebody help me? Can't locate how-to using "search".
TMac, Josh89 and Llia like this.
__________________
2017 Autocross
The RS prepared (somewhat) for Street Mod Front Drive.
1. Wavetrac
2. Chevy perf. clutch
3. BNR tune
4. Ported intake
5. Eibach Pro spring kit
6. ZZP rear sway
7. ZZP Lower control arms
8. ZZP Lower trans mount
9. Hawk HP+ front pads
Photo by:
Jason Massey
www.jpmmedia.com
Last edited by 4Flattires; 08-09-2017 at 01:45 AM. Reason: Pics not working like they used to. Requesting help. Trying more for pics.
4Flattires is offline   Reply With Quote
Old 07-31-2017, 01:35 AM   #2
Senior Member
carsNskis's Avatar
Garage
Default
On the web or using tapatalk app?
Web: upload the photo to a hosting site like Google photos, etc. Copy link.
click Insert image button
Paste link
Tapatalk: much easier because you can upload from your phone gallery, Google photos, or use the camera live
carsNskis is offline   Reply With Quote
Old 07-31-2017, 01:37 AM   #3
Senior Member
carsNskis's Avatar
Garage
Default
Good luck in the races, looking forward to seeing how you do!
Old 07-31-2017, 03:48 AM   #4
Senior Member
Garage
Default
Good job sir, neeeeed those these pics!
Sent from my iPad using Tapatalk
__________________
13 Sonic RS | Summit White
cuartz7o is offline   Reply With Quote
Old 08-05-2017, 02:43 AM   #5
Senior Member
Garage
Default
Which of those mods makes it SM? LSD? I think you'd still be fsp.
Either way have fun. Hope you have better luck than i did.
-RuD
__________________
2013 Sonic LT 1.4/6M black.
Build thread:
http://www.sonicownersforum.com/foru...urd-sonic.html
sw2low is offline   Reply With Quote
Old 08-09-2017, 02:22 AM   #6
Default
-RuD
Dear RuD,
My read of the rules suggests that the heim joint in the LCAs put me in Street Modified (SM). Replacement of a bushing with a spherical bearing does not appear to be allowable under Street Prepared. SM is the lowest class that takes basically all limits off suspension, engine, tune, and other things.
Just to be clear, I am in this for fun and enjoy suffering with the other drivers for a whole Sunday. Don't get me wrong, I have 5 regional class championships, a Tire Rack Index top 10 finish, and a trip to nationals (2015) where I did not finish last. I do like to win. SM is not the class for a Sonic though. If I wanted to be clever, I would have left out the Eibach springs and the LCAs and I could have cheated my way as far as possible into H Street. The Wavetrac, stout clutch, and maxed-out BNR tune might make the Sonic competitive-ish in HS and are completely invisible. If I was a top-tier driver it might add up to something. I am upper tier locally, but a bottom feeder on the national level.
carsNskis likes this.
__________________
2017 Autocross
1. Wavetrac
3. BNR tune
4. Ported intake
6. ZZP rear sway
Photo by:
Jason Massey
www.jpmmedia.com
Last edited by 4Flattires; 08-09-2017 at 02:24 AM. Reason: qualification of a statement
Old 08-09-2017, 02:35 AM   #7
Default 2017 Hoosier Challenge SCCA Autocross, Hosted by the South Bend Region
This is at the historic Grissom AFB every year in recent memory. There were over 200 drivers on Sunday. The Saturday before is just an SBR points event.
[IMG][/IMG] Ready-ish for the Hoosier Challenge.
[IMG][/IMG] On the grid for three runs.
[IMG][/IMG] Also on the grid.
On Saturday there were 4 drivers in SM. A nice young lady from South Bend driving her VW R32 got me by 0.6 seconds on a 60-second course, so it was a 2nd place finish out of four drivers.
On Sunday (the actual Hoosier Challenge) there were 8 drivers. I placed 4th on a power-oriented 55-second course. A tricked-out BRZ shared by two drivers got me by 4 seconds. The nice young lady in her R32 got me by 1.6 sec.
I have a several local regional events left through October and look forward to all of them. The Tire Rack test track is one venue that usually favors a car like the Sonic, and there are two of those left. I think I can get the R32. Two years ago while in HS, I beat her every time. Her driving has improved a lot though.
May the force be with us.
carsNskis, Llia and cuartz7o like this.
__________________
2017 Autocross
1. Wavetrac
3. BNR tune
4. Ported intake
6. ZZP rear sway
Photo by:
Jason Massey
www.jpmmedia.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
