Of course man. No problem. I just landed in Alabama and I may not have those pics with me. Might need them to refresh my own memory. But I remember it was tight. Use your left hand with a lonnngggg screw driver to loosen and with my right hand I held one of those long flexible pick up tools. The king you squeeze and it has a little claw that opens up. In the pick up tool claw I had it holding the magnetic tip of a magnetic pick up tool. And I just dropped it straight down and had it stick to the screw. When it comes all the way off, you just lift it out! Then on to the next one. Get them all broke loose first. Controlling 2 tools with 2 hands at the same time was a little nerve wracking. That and the angle you're bent over the car. Getting them back in will be a similar deal. You gotta get the screw stuck to the magnet at an angle you can put the screwdriver tip on it.
And don't mess around trying to snug one bolt. Get them all on at least a half turn first. If remember correctly the screw closest to the engine was tougher to get because the angle on the screwdriver was not straight on. So did that one first. Then you'll have press the BOV on with your hand and make sure the spring is seated correctly. I think I got it with my left and when it was situated good I reached straight down with my right hand to keep it in place and had my long screwdriver ready to reach back in with my left hand and snugged one bolt so it wouldn't pop out of place. Then the other two were easy. Lay a folded towel or something where you're leaning on the car and just know you're going to scratch the next out of your left hand. It's tight! But you know that already.
Best I can do from memory right now. If you want pm me an address I can email you the pics I posted before.
Hope this helps.
Sent from my SM-G930V using Tapatalk
