cmgeiser
incase anyone wanted to know how I got an aftermarket camera to work with the MyLink system here it is in a nutshell -
WARNING - I am not a professional and don't pretend to be if you want to use this method do so at your own risk.
Now let me tell you its a bit flakey but because the MyLink system will switch automatically between sources, when you put the car in reverse the video will display on the screen most of the time again its flakey and remember if you go over 5mph the video will cut out.
1. attach and wire up camera (use the instructions that come with the camera)
2. take the video cable and attach it to an AUX video cable
3. plug the Aux cable into the Aux input in the car next to the USB
4. put car in revers and video will display on the MyLink screen
