ca, car pcv fix with throttle spacer pass smog visual ???
Has any one done this fix that lives in a smog state like Ca, I seen the thread I have a 13 RS and I noticed at high boost I hear a hiss like air is escaping somewhere I got under the car and it kinda looked like the oil pan was starting to leak ,I have only 24k miles on the car but I am interested in doing the fix with the throttle spacer since it's easier to service I have a trifecta turbo advantage tune since that's all I can get away with here , although if I do the Other mod and take off the intake I would probably port it at the same time . He said 40 to 50k without needing to service the valve I'm just wondering if I would fail the visual with the spacer installed ????
