Maddmatts
Kudos to Blue Angel on the Cruzetalk forum for this DIY:
DIY - Oil Pan Heater Thermostat Removal
I came across this while trying to figure out why the oil pan heater has a thermostat that only allows it to operate when ambient temp reaches -18C/0F or lower.
The bypass basically involves:
1) Remove the black circular cap on the heater plug. The cap is easier to remove/install if the rubber surround on the plug is warm and pliable.
2) Remove the little metal thermostat switch.
3) Pull up the two tabs and solder a 16ga or larger wire from one tab to the other.
4) Reinstall black plastic cover.
More detailed instructions with pics are in the link above.
It turns out the reason for the thermostat wasn't entirely arbitrary or due to liability concerns like I would have thought. The ECM compares the readings from the IAT and ECT sensors during cold starts to check for faults. Engineers wanted to keep the heater from causing the ECT sensor to read too high compared to the IAT causing false positives.
The thermostat's setting is fairly conservative and you can get away with using it on warmer days. Not that I suggest using it in the summer, but I've always felt that -18C was a little late to start using it.
