had a little bit of weather stripping poking out since i got the car and finally decided to put it back in.
there are 8 pop clips and a screw that hold the rear plastic to the hatch. the screw is located in the handle.
i started up at the rear window and just worked my way around, i broke one clip so be wary on how hard and at what angle you are pulling.
once that piece is off, 4 10mm nuts and another pop clip hold on the rear strip
i took the nuts off first then pulled on the strip while pushing on the white clip to get the strip off.
hope you guys find this helpful, think im gonna take it off again this weekend if i can get my hands on some vinyl
