It feels as though it is fiberglass. Depending on the color of paint you are using next you may not need to use that coarse of sandpaper. I would just take the clear coat off. That can normally be achieved by using a wet sandpaper block. I'd use 800-1000 grit. Anything lower than that will leave grooves.
