Go Back   Chevy Sonic Owners Forum > Chevrolet Sonic: General > Factory Specifications
Like Tree11Likes
Reply
Old 02-02-2015, 07:04 PM   #11
Senior Member
ScarabEpic22's Avatar
Default
Not a simple answer as the ECM will control boost levels to make the desired TQ value it is programmed with.
Ive seen ~165kPa maybe 170kPa on my 13 RS 6MT, take ~101 as atmospheric so thats ~65-70kPa (9.5-10psi) of actual boost. I live in Seattle so I'm at sea level or a few hundred feet above.
__________________
~Erik~
13 Chevy Sonic RS Manual CGM, sunroof - mods in process
08 Chevy TrailBlazer SS LS2 AWD - loaded, dropped, tinted, just a few mods..., SE22 Performance tuned
02 Chevy TrailBlazer LT 4WD - loaded, lifted, SE22 Performance tuned
ScarabEpic22 is offline   Reply With Quote
Old 02-02-2015, 09:29 PM   #12
Lead Foot
Natesriv's Avatar
Garage
Default
I bump 11-12 SOMETIMES (I'm in an LTZ)...but mostly 10 when I punch it.
Natesriv is online now   Reply With Quote
Old 02-02-2015, 10:32 PM   #13
Senior Member
Default
Search over on cruzetalk it's a few post stating up to 18 was seen but I'm having issues loading the site
Max I ever got stock was 16.5 on my cruze
Sneakerfix is offline   Reply With Quote
Old 08-20-2016, 11:34 PM   #14
Garage
Default
Im at Mile high in Thornton, CO. before I was tuned I would hit 16lbs. that's peak boost in third gear. the ecu doesn't give full boost till 3rd gear because of danger of damaging axles/ transmission, ect...
carsNskis likes this.
Tyler13999 is offline   Reply With Quote
Old 08-21-2016, 08:16 AM   #15
Senior Member
carsNskis's Avatar
Garage
Default
Quote:
Hello fellow CoSonic! I'm in Littleton, work at Century in Broomfield. Stop in some time and say hey!
carsNskis is online now   Reply With Quote
Old 08-21-2016, 08:20 AM   #16
Garage
Default
Quote:
I have man! The orange lt on cruze Eco wheels and E85. Let's cruise peak to peak soon. I've got Tuesdays and Sundays off! Pm me
Sent from my SM-N910T using Tapatalk
Old 11-05-2017, 11:36 PM   #17
shibbs's Avatar
Garage
Default
So I just did some logs with the Torque app and a bluetooth OBD2 adapter and only got 9.8psi peak, and 9psi hold. Does this seem right?
Specs:
2018 RS Hatch, 6-speed, with the GM Performance exhaust and tune
Outside temperature was just above 0 C / 32 F.
shibbs is online now   Reply With Quote
Old 11-06-2017, 11:24 PM   #18
Senior Member
Default
See my previous post #11 in this thread.
I'm close to sea level and see anywhere from 9-14psi depending on spark timing and fuel I'm running. Seems close to me for a stock ECM calibration. You have the GM exhaust one, I don't know what that does as far as adjusting the desired TQ value (which adjusts desired boost).
__________________
~Erik~
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
