Llia
Been working on a hood vent for myself. Would like to see if it is something others would be interested in. I still have fit, finish, and durability testing to churn through. May do some before and after temperature readings but I'm positive it will do what I expect it to do.
The design was dictated by the hood supports. I wanted to avoid cutting into structural bits. Also I tried to place it close to the radiator to take advantage of low pressure near the front of the car. Regardless, the vent slats are arranged in a way I hope promotes good low pressure to draw out hot air at nearly any speed or hood placement.
Decided to file vs fill print lines.
