Hi guys,
So my sonic just hit 200,000 miles this week and I can tell the engine is a little tired and the 6mt trans make quite a bit of noise. I would like to replace both at once, I like this little car and would rather not get rid of it. It's at 2012 LTZ 1.4T/6Mt, my question is what years can I use to replace my engine and trans? Are 2012-13 the only 2 years I can use? I noticed later models require a different clutch then those years. Also, I if i find a low mileage engine out of an auto, can I use it in my car with manual trans? Are there any variations between the two beside the flywheel and flexplate? Any info is greatly appreciated, thanks. PS.....this car has been running 20psi if boost for of 100,000 miles of its life....:banana:
