Go Back   Chevy Sonic Owners Forum > Chevrolet Sonic: General > General Discussion
Like Tree18Likes
Reply
Old 12-06-2017, 03:18 PM   #1
Junior Member
Garage
Unhappy Chirping sound from dash, convinced its HVAC fan
Hi all!
I'm a really new Sonic owner, and I love my car so far except for this one nagging issue! I've been having an intermittent "chirp" sound coming from my dash. I initially thought HVAC fan, so I brought it to my Chevy dealer and they kept it for 3 days because they couldn't reproduce it. So naturally, they dismissed my theory immediately.
Ended up changing my air filter (it was in backwards?) and said they thought the noise was because my timing belt cover was loose on all 4 bolts. So they fixed that, and sent me home with a bill since that stuff was not covered by either my power train warranty or my vehicle protection plan because it was considered "maintenance" repairs. (grrr).
Fast forward to 2 days after I get it back, and I'm hearing the noise again!!!! It happened this morning on my way to work, so I played with the fan a little while it was happening. It's definitely the HVAC fan, because when I turn it off I can actually hear the noise winding down with the fan.
So now I'm frustrated because I don't want my car to be in the shop AGAIN, only to be told they can't reproduce it and charge me another fee. It's in the middle of winter and the last thing I want is for my fan to go out! Any advice is welcome, I'm not sure what I should do now.
Zapps98 likes this.
__________________
I dream in Kinetic Blue...
2013 Sonic LTZ
nerfworthy is offline   Reply With Quote
Old 12-06-2017, 04:21 PM   #2
Senior Member
Garage
Default
My fan was noisey for about 2 years, and I just let it be. They are known to get noisey. I would contact chevy customer service regarding your dealership visit. It would be a comeback it you came in for the same problem, so it would be on them if they can find nothing wrong.
Zapps98 and nerfworthy like this.
__________________
GM Parts Counterperson
If you have any questions regarding parts, feel free to contact me!
2017 Mosaic Black 1.4L Auto RS Premier Hatch
GM lowering kit
Upcoming:
ZZP Catback - 2nd cat delete
MPFab Intake
BNR Tune
Hectic is offline   Reply With Quote
Old 12-06-2017, 05:24 PM   #3
Junior Member
Garage
Default
Thanks for the advice! I decided to call the guy I'd been working with and let him know whats going on. They are going to order the fan motor and bill it to my extended warranty, and if there's a deductible they are going to take care of it for me!
Zapps98 likes this.
__________________
2013 Sonic LTZ
Old 12-06-2017, 08:31 PM   #4
AlphaWhiskeyPapa's Avatar
Default
Mine seems to be doing the same thing, coming from the passenger window vent. Let me know what they come up with at the dealership.
Sent from my XT1254 using Tapatalk
AlphaWhiskeyPapa is online now   Reply With Quote
Old 12-07-2017, 03:50 AM   #5
Junior Member
Zapps98's Avatar
Garage
Default
Iím having the exact same problem! Itís definitely coming on the passenger side, happens when air is hot & cold, and slows down with the speed of the fan when I turn down the vent power.
nerfworthy likes this.
Zapps98 is online now   Reply With Quote
Old 12-07-2017, 04:33 AM   #6
Garage
Default
This is gonna sound really crazy guys, but I had a similar noise problem, and I swore up and down it was AC related because at idle with the fan off, I wouldnít hear it, but when I turned the fan on I got a crystal clear chirp, and I couldnít tell where... tore everything apart and cleaned my hoses, replaced the hvac and still was there... this is gonna sound dumb but... it was actually a loose spark plug causing the chirp, it had burned my coil pack as well, if youíre not checking for correct torqued plugs, and making sure your coil boots look fine, please start doing that every 5k miles or so. It takes 5 minutes flat, and you can do it when you change your oil. Best of luck!
Zapps98 likes this.
Espysonic is offline   Reply With Quote
Old 12-07-2017, 08:34 PM   #7
Junior Member
Garage
Default
I managed to take a few videos of the sound happening to show the mechanic. I also have a new symptom of a weird mechanical noise happening if I shut off the car with the fan running. Please see them here!
Mechanical noise:
https://drive.google.com/open?id=1b-...iQiVkn7MKDPUQ_
Chirpy cricket while air is running:
https://drive.google.com/open?id=14m...mOwLTJI5EOMPRm
https://drive.google.com/open?id=1eJ...9YUoAWIKW1OFoX
Zapps98 likes this.
__________________
2013 Sonic LTZ
Old 12-08-2017, 05:20 PM   #8
Junior Member
Garage
Default
Taking my car and the videos to the mechanic this afternoon after work. Wish me luck and pray the mechanic isn't deaf to the high pitched decibel the chirp is at
Zapps98 likes this.
__________________
2013 Sonic LTZ
Old 12-08-2017, 07:31 PM   #9
Junior Member
Zapps98's Avatar
Garage
Default
Quote:
Good luck! Let us know what they say, if anything!
Old 12-08-2017, 07:32 PM   #10
Junior Member
Zapps98's Avatar
Garage
Default
Iím definitely gonna check this! I didnít even think about that as a possibility
Espysonic likes this.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
