AS
The 1.4L turbo is problem prone no matter what year.
But 2014 and later should have the upgraded water pump and maybe one or two other slight improvements. It is what it is.
Pre-2014 turbo issues are well known, but saying they're all problem prone is wholly false.
My 2014 RS manual has 70k on it and I've only had an o2 sensor and pcv/valve cover replaced, both under warranty. My hvac blower is starting to chirp a bit because I RallyCross and have never changed the cabin filter, some blame that on bad design but I find it debatable.
Besides Whitesmoke and a select dozen or so others I probably drive my Sonic harder than most in the Country (that is not an exaggeration). I can't assure all Sonics are great, but mine has been.
[emoji593][emoji809][emoji472]
