So a new TTR transmission mount is $120. A new stock transmission mount is $22. Has anyone attempted to fill the gaps inside the stock mount with urethane as in this thread?
>>>>http://www.sonicownersforum.com/forum/do-yourself-articles/7396-diy-poly-rear-lca-bushings.html.
I don't know what TTR uses as their urethane stiffness, but i was thinking that since most manufacturers use a relative stiffness on stock mounts of A40, you could use A60 and get a good balance between the softness of the stock mount and the stiffness of a filled mount.
