Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Technical > Handling, Braking and Suspension Discussion
Like Tree2Likes
Reply
Old 06-19-2017, 02:42 PM   #11
Senior Member
Garage
Default
Quote:
Originally Posted by Syrup View Post
Make sure you are using the correct bump stops too.
-Syrup
Zzp doesn't include new bump stops. Options are keep stock bump stops intact or cut the first ring off for a bit extra movement over large bumps.
Sent from my SM-G925T using Tapatalk
__________________
13 Sonic RS | Summit White
BNR 91 Octane Tune, Ported Intake Manifold, Bypassed, 3" Hard Pipe to SAB w/ K&N Filter, Borla ProXS Muffler, ZZP Lowering Springs & End Links, MTech M32 Short Shifter, DDMWorks Shifter bushings, DDMWorks Rear Suspension Brace, Ultragauge EM Plus, LED Yellow Fogs, Philips Diamond Vision Low Beams, WeatherTech wind deflectors, LED interior, Pioneer TSSWX2502 10" sub & GM-D8601 mono 300W
cuartz7o is online now   Reply With Quote
Old 06-19-2017, 09:02 PM   #12
Garage
Default
I trimmed the fronts. There weren't really rear bump stops that were trimmable. There was the metal cone that the spring is installed over.
Its not riding on the bump stops.
Thanks gents.
__________________
2013 Sonic LT 1.4/6M black.
Build thread:
http://www.sonicownersforum.com/foru...urd-sonic.html
sw2low is offline   Reply With Quote
Old 06-21-2017, 01:52 PM   #13
Senior Member
Syrup's Avatar
Garage
Default Bouncy rear end w/ zzp springs
Thanks gents.
Rear bump stops are on the shocks.
-Syrup
__________________
2014 1.4T LT Hatch
moustache-delete
RS seats, floormats, and shifter
17" Sparco Assetto Gara wheels
lowering springs
mudflaps
shifter bushings
OEM fog lights
Syrup is offline   Reply With Quote
Old 06-22-2017, 10:43 PM   #14
Garage
Default
-Syrup
This is fantastic information. Thank you
__________________
Build thread:
Old 06-23-2017, 02:41 PM   #15
Lead Foot
Natesriv's Avatar
Garage
Default
bad shocks... get KYB's and never use the crap OEM's again!
__________________
https://s-media-cache-ak0.pinimg.com/736x/de/20/50/de2050af4e1474403e8da25727cf9364.jpg
Natesriv is offline   Reply With Quote
Old 08-11-2017, 10:26 PM   #16
Garage
Default
-Syrup
This was it, it was riding on the stock bump stops. Cut an inch off them, couldnt get the oem plastic boot off, so i couldnt cut all the bump stop i wanted.
Doesnt bounce any more, rear end come down a 1/4" too.
Thanks again.
__________________
Build thread:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
