Hello Guys,
I posted this in the maintenance subsection, thought this would be more appropriate here.
I am preparing to replace all brake parts on the four corners. I plan to completely replace everything, drums, rotors, pads, springs, ect..
This brings me to my first question. Rockauto shows a left and a right drum brake self adjuster. Is it necessary to replace these? How do you initially set them up? Next question is, I plan to put the car on jack stands, where is the safest place to put the the stands, both front and rear?
Planning on getting a manual impact wrench for the philips holding the rotor and drums on. Other than the parts, what else is there? Any anti seize or silicone to use?
This will be my first brake job. Thanks so much for any suggestions or help!!!!
