@ UltimaSanctus Are you saying with 4 adults in the car that you bottom out a lot? I like my LT w/ 15" wheels but want to tighten up the suspension by replacing stock shocks and strut with RS version and springs. I just don't want to scrape everywhere. It's can be bad now I just don't want to make it worse.
I was really on the fence about drop springs (cheapest) vs GMP (500ish) vs cheap coil overs (800ish) vs BC or better... i think the GMP is the best ride quality for a daily after riding in other Sonics with springs only (but the stiffer drop springs do limit body roll better). If budget is the priority start with springs, worst case you don't like them you can sell them and go back to stock until you find another route to goThank you both for the input. I just want to be careful before I dump a lot of money into the car which I won't get back and may not be happy in the end.I'll most likely look at this after the winter.
Yeah I looked at those too. There not much cheaper then the zzp springs. And zzp is about an hour drive from me so if I can support a michigan company I don't mind paying a little more.I am running the Meagan springs and they are been cheaper and ride great and lower it just enough.
Hell yeah man. High FiveAhhhh, 10-4. I’m from Michigan too and never realized they were located there or I woulda bought from them as well. Now I know.
Oh I see, I might not want to get these then. Lowering is the man thing I want to do. I want to try and reduce how much the the nose dips and lifts off braking and accelerating.The zzp springs definately get the car looking better, and the ride quality is also good. Almost too good. The rears feel softer than i'd like. The ass end sags when i leave from a stop. Havent ridden on any other sonic springs to compare to though.
Id also recommend the sway bar.
Sent from my SM-G955U using Tapatalk
