Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Technical > Handling, Braking and Suspension Discussion
Like Tree50Likes
Reply
Old 12-01-2017, 09:03 PM   #61
Senior Member
Blue Moon Sonic's Avatar
Garage
Default
I hope everything is ok. Sounds like you need a vacation. Work is not fun to deal with when things get hectic.
__________________
In soviet russia, you don't choose the car you want to drive. The car chooses the driver.
12 Chevy Sonic 1.4T ltz - Back to Daily status, Sonic RS Auto trans swapped
2008 Ford Mustang: Engine Swapped from a v6 Building for Pikes Peak in 3-4years. Need more funds and sponsors. -retired till spring
2006 AWD Pontiac Vibe - Retired for emergency use only. LS swap planned.
2012 VW Golf R 6spd manual -Stage 1. In storage till new tires go on.
Blue Moon Sonic is online now   Reply With Quote
Old 12-02-2017, 09:25 PM   #62
Senior Member
Gimpster's Avatar
Default
Arms showed up today, look great! Can't wait to put them on. Pardon the Honda engine in the background, my bench was full of junk from working on it
__________________
2013 Chevrolet Sonic - LT 1.4T M6
Gimpster is online now   Reply With Quote
Old 12-02-2017, 10:12 PM   #63
Senior Member
Garage
Default
Those bushings look eons better than the factory crap. Now I'll have a reason to drive devil's lake after install.
Gimpster likes this.
__________________
Old 12-03-2017, 12:21 AM   #64
Senior Member
Default
They are way better, they allow zero slop laterally while being fully flexible. It's the perfect fit for this application, but they cost 20x more than a wad of rubber in a metal ring and they transmit more "noise" in the sense of road feedback.
Gimp, do me a favor and double check the tightness of those ball joint bolts once you have it bolted to the car, they should be plenty tight but I was doing it on the bench with two wrenches, normally i'd be using a bar and socked. They have locking nuts and don't require a ton of torque but just make sure they're all good.
Also, the bushing sleeve and the spacers are mild steel, i'd coat them with grease to keep the rust down. I was thinking about painting them, but if they get scratched during install, they will rust anyway so it didn't seem worth it.
__________________
'13 Inferno Orange Sonic LT Hatch 1.4/6A - Wife's
'03 MB CL600 - 12.4 @ 115 stock
'97 Toyota Tercel Redhawk - daily beater
'91 Toyota Paseo - boosted, gutted, rusted, garbage
Italianjoe1 is online now   Reply With Quote
Old 12-03-2017, 01:28 AM   #65
Senior Member
Garage
Default
I'm used to the sound and feel of metal bushings down the road. Gives more response when cornering and with greater confidence.
__________________
Old 12-10-2017, 03:56 PM   #66
Junior Member
Default
Quote:
Those look amazing! Iím in for purchasing these. PM sent Italianjoe. Thanks for putting this into action Gimpster!
CorradoKev is online now   Reply With Quote
Old Yesterday, 04:14 PM   #67
Senior Member
Garage
Default
Hopefully will install mine tonight. Though, I definitely should've sprung for the removable ball joints Oh well, I absolutely love the bushing design regardless. Thank you Joe.
__________________
Old Yesterday, 04:33 PM   #68
Senior Member
Default
Quote:
I don't think the ball joints are a necessity, the sealed ones are usually long life anyway, it's not like old cars where ball joints went bad every 30-40k miles.
Worst case, you can always add them later, just drill the rivets that hold them out, and bolt in the new ones.
__________________
Old Yesterday, 07:17 PM   #69
Senior Member
Garage
Default
I'm not too concerned.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
