Be someone. Learn something. Install yourself.
Even after the 80PRS head unit install, the 14Wrms per channel wasnt enough for aftermarket speakers (had Pioneer coaxials at first, but switched all that out). Then I got a 4 channel amp and WOW what a difference. Crystal clear sound.
I ran all new speaker wires to all doors and installed coaxials in the back doors. Installed a component set in the front, with crossovers installed inside the center console against the kick panel.
I had to remove the front doors from the car to drill a hole in the door jamb pillar (on the car side) to run the new wires. Dont just drill thru the outer wall, theres a second interior wall to drill thru. Take your time and clean up the burrs on the drill hole. Use at least a 1/2" drill bit, although I recommend larger. I ran two runs of 12ga wire thru there, one for tweets, one for mids. The rear door is a cake walk since there are plastic grommets on both the door and the car-side door jamb.
The rear door speakers are in an awful stock location, but they make a big difference once theyre amplified, as 007 pointed out.
I lost all the install pics from that portion of my sound install bc my phone wigged out. Although, I can post a pic of the crossover mounting location and the speaker wire runs thru the door jambs if anyone is interested (when I get home on Thursday).
