[emoji23] [emoji23] [emoji23] [emoji23]centers look like a frog
I like the center style as that area is sort of a waste of space, at least to me. I like the look of this one as opposed to the ZZP, but I'm concerned about the angle of the gauges. They appear to be pointing upward a little too much. I also dig the pillar gauges but am concerned about the gauges becoming projectiles from the airbag in there.
Sent from my Nexus 6 using Tapatalk
You could've bought a 2012-2016You all think it's a PTA to find a place to put gauges in your 2016 or older sonics?
Try in the new 2017 RS!!! The top dash is different and there no room at the bottom either. Groan.
2017 Sonic LT RS
1.8L Ecotec
6 Spd AT
Red Hot
Sent from my iPad using Tapatalk
You could've bought a 2012-2016 [emoji41]
What issues are you currently facing with your model/year Sonic?Yeah this is true but I wasn't aware of the differences until after I bought and like the '17 regardless. I'll find a way to install gauges at some point and will share my install when that time comes.
2017 Sonic LT RS
1.8L Ecotec
6 Spd AT
Red Hot
No problem. Sharing is caring!Mzooski thanks for finding this. I wasn't aware of anyone that made a pillar. Although the price tag is not appealing.
I have 3 gauges with the zzp pod, so one doesn't have an official home. With a double pillar and zzp pod, ill just have to get another gauge!
I was looking at that area in pics (I'm currently deployed) if you got the A pillar gauges pods, I wonder if the tweeters could be relocated to that triangular trim piece hiding the bolts for the side view mirror. I want to replace the speakers also, so this is something I'm looking into. Might have to tear the interior apart when I get home.Now that you mention it, that looks about where my tweeter is. Not in the way of the air bag which is up higher. Can't get rid of my tweeters though.
I was looking into that. I might see what I can fab up. Shouldn't be hard, more than likely just time consuming, which unfortunately I don't have a lot of, lolI haven't seen any specific to the Sonic but I suppose you could modify a steering wheel pod for another make
