I have read several posts that were kind of similar to this fault. There was a recall I believe about a fuel vent line clamp issue which allowed a loss of pressure that would cause these codes. And one gentleman's issue where they misdiagnosed his problem and changed his intake manifold twice but did not fix problem. After a Specialist came out to look it appeared to be a wire chafing issue common to his environmental control system, but didn't go into detail of which wire connector it was common to. I'm pretty sure this isn't a bad Gas cap that seems to be the first area to look. Is there an issue with this system that is becoming common, or at least common enough for someone to lead me in the right direction. I have 82,000 miles on my car now and pretty sure it is out of warranty. Unless this condition falls under powertrain which is 100,000 miles I think. Afraid to take to dealer and have large bill if I can live with this issue.
Does anyone have any advice or suggestions for me?
Sam
2012 Sonic LTZ 1.4L Turbo 6 speed manual transmission sedan.
Sam
