Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Technical > Maintenance and Care
Like Tree122Likes
Reply
Old 04-23-2013, 11:47 AM   #341
dvn
Senior Member
dvn's Avatar
Garage
Default
Quote:
Originally Posted by Wong View Post
Did my first oil change today... bought mobil1 5w30 and a wix filter.
Jacked the car up and....
...no belly pan
Changed it in like 30 mins when I thought it would be an hour ordeal.
The belly pan adds about 2 minutes to the job.
__________________
2012 Black Sonic LTZ 1.4T MT Hatch
dvn is offline   Reply With Quote
Old 05-07-2013, 03:22 AM   #342
LoneRider's Avatar
Garage
Default
I changed mine today and it was easier than the OP made it out to be. I didn't have a splash guard where the drain plug was, in fact, the only splash guard I saw was under the radiator. I didn't need a special tool to remove the oil filter cap, since I didn't have a 24mm wrench, I used a 1/2" drive 15/16 socket with extension and it fit rather well.
This was one of the most pleasant cars I've ever had to change the oil on. Had no mess to cleanup other than used rags, garbage, and tools. No more oil running down my arm when changing the filter! And 4 quarts of oil was just right, no need for the .2
__________________
Victory Red Sonic RS 6/M wo sunroof
LoneRider is offline   Reply With Quote
Old 05-12-2013, 01:33 PM   #343
T-BONE's Avatar
Garage
Default
Quote:
Originally Posted by wingman View Post
So its either ramps or a two jack raise for an oil change. This is getting complicated. Still informative. Im sure by the time I am ready to change mine, y'all will have this so detailed its down pact!
actually you can avoid the two jack need as follows. Drive up onto two boards that are 1-2" thick. stop. jack car with extra clearance. just remember to keep the boards where they are when you lower the car.
T-BONE is offline   Reply With Quote
Old 05-12-2013, 01:35 PM   #344
T-BONE's Avatar
Garage
Default
Quote:
My Spyder also has a belly pan ( we call them diapers). Easy to drain oil but you have to take it off to access the filter. Many folks just leave them off. Once you get used to pulling them its a trivial exercise.
Old 05-19-2013, 11:42 AM   #345
Senior Member
Default
Agree!! Wix is an outstanding filter.
LTZ ICE is online now   Reply With Quote
Old 05-22-2013, 06:59 PM   #346
Senior Member
Default
Yep, I bought the belly pan since my 2013 1.4 hatchback didn't come with one. It is absolutely no big deal to pull it off for an oil change.
Roll the car up on ramps, remove the front two bolts from the belly pan, loosen the other 2 or 3 (they're keyholed) and off comes the pan. Drain the oil, spin off the oil filter cover, replace oil filter, tighten oil filter housing cover and put 4 quarts of Dexos1 compliant oil in the engine. Place bellypan back in place, replace the two bolts and tighten all. Back the car off the ramps. Check and add oil as needed until full. If this takes you more than 30 minutes even without trying to be quick, you're just not organized.
MartyH is offline   Reply With Quote
Old 05-25-2013, 11:08 PM   #347
Fry
Senior Member
Fry's Avatar
Garage
Default
So, was going to change my oil this weekend, but other things came up and stalled that activity out. I believe, however, I have everything I need. I've got a 2T floor jack and some 3 ton jack stands. Having never jacked a car up or changed the oil on a car, I'm going to have a friend come over who knows what he's doing to guide me through the first go round. Jacking the car up and supporting it are the things I'm most unsure of, mainly because I see an obvious risk to someone who is inexperienced (ie, me). I feel like this is something that should have been taught to me years ago. Of course, that's why I'm going through all this trouble.
Btw, are the lift points in the Sonic's manual? I looked through but didn't notice them.
Scotiez likes this.
__________________
On communicating
Fry is offline   Reply With Quote
Old 05-26-2013, 12:21 AM   #348
Senior Member
Garage
Default
I just use ramps from advance auto. Drive up, change. No sweat.
oldertech is offline   Reply With Quote
Old 05-26-2013, 12:28 AM   #349
Senior Member
Kuntryboy865's Avatar
Garage
Default
Can someone point me to a filter that will work with the sonic?
__________________
BNR Tuned
ZZP intake
ZZP second cat delete exhaust
Ported intake manifold
Bypass mod
Sparco assetto grara wheels
Passenger side headlight delete for cold air intake
DDM Silicone Coolant hoses (red)
DDM Hard Charge Pipe
Forge Motersports BOV
Ultraguage
Kuntryboy865 is offline   Reply With Quote
Old 05-26-2013, 04:54 AM   #350
Senior Member
sx sonic's Avatar
Garage
Default
Quote:
Try the dealership!
I run a Hastings filter # LF642 that I get from Fisher Auto/Federated Auto.
Most auto stores can pull up the correct filter/s on the computer in 2 minutes. A few others leave the research to you and set a book out by the filters that you can dig thru and find various filters that will work.
Edit: I found this thru google. Those part numbers should work at any auto store as long as they carry that brand of filter.
Link 2012 CHEVROLET SONIC Oil Filter
It also looks like the 1.4t and 1.8 use the same filters.
__________________
2012 inferno orange hatch, 1.4T 6M/T
sx sonic is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
