Hey guys,
The biggest problem for most of my customers when installing the MPFab intake is getting the gasket to make a sharp turn or just stay put. I've put together a pictorial showing the sequence of events that must occur to properly install the gasket in order for it to do these things. Very simple to do, and should prevent your money from landing in the swear jar.
Notice I did NOT cut the outside.
Tightening the seals grip is easy. SLIGHT pressure with pliers is all you need.
