Go Back   Chevy Sonic Owners Forum > Chevy Sonic: Vendor Forum > Morgan Performance Fabrication
Reply
Old 07-28-2017, 02:31 PM   #1
Boy-Dirt-Car's Avatar
Default MAF Screen Install
So I'm fitting everything up today to install my new MPFab CAI kit and I'm wondering where to fit the MAF screen honeycomb.
It just fits inside the rubber coupler. Does it stay there, between the Intake tube and the Velocity Stack? The instructions say to push the Velocity Stack into the rubber coupler until it contacts the Inlet Tube. I'm assuming the screen is in between the 2... Am I right in thinking that?
Boy-Dirt-Car is offline   Reply With Quote
Old 07-28-2017, 08:21 PM   #2
Senior Member
Garage
Default
Not to be a dick, but a little bit of searching does wonders. The instructions are right on the MPFab website.
MAF Honeycomb for MPFab Sonic Intake System - Morgan Performance Fabrication
It is pushed into the velocity stack itself, not between the two.
__________________
GM Parts Counterperson
If you have any questions regarding parts, feel free to contact me!
2017 Mosaic Black 1.4L Auto RS Premier Hatch
GM lowering kit
Upcoming:
ZZP Catback - 2nd cat delete
MPFab Intake
BNR Tune
Hectic is offline   Reply With Quote
Old 07-28-2017, 08:26 PM   #3
Default
Ah, I did not think of looking at the part itself, I was just going by the provided installation instructions...
Thanx!
Old 07-29-2017, 02:50 PM   #4
Senior Member
RMinNJ's Avatar
Garage
Default
Install in the metal funnel itself at the tube end. I put 4 dabs of epoxy like the online instructions said also.
RMinNJ is offline   Reply With Quote
Old 08-03-2017, 04:06 AM   #5
Supporting Vendor
Default
Quote:
Thanx!
Did you purchase it from me or BNR? I Email the installations guides when the part ships. BNR has them on the site. I'm not sure if they have the honeycomb instructions though. I have a nice PDF I can send you that is far more in depth than the short description on the website. You shouldn't need epoxy.
__________________
2013 Sonic HB MPFab"Test Mule"
Current EFR6258 numbers...
315whp@6,250
285wtq@4,700
MPFab is offline   Reply With Quote
Old 08-17-2017, 01:20 PM   #6
Default
Got it from BNR.
I had to scrunch it a bit around the outer edge but I got it to fit into the VS without deformation to the screen.
Thanx for the reply!
P.S. I did not use any epoxy, it's not going anywhere!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
