Ok went for first full fill up on my dusk 6 speed. Handle clicked then hit it again and clicked again and wanted to see what's the most this tank will hold (IN EMERGENCY) long haul. I know about evap system but I just like to test it like I did in the last bar being gone and miles left on my other thread.
Ended up pulling hose out of filler and slowly filled up tank. I put in 3.1 gallons in it. Is this normal or bad gas station filler? I can't see gm leaving this much on the table even for evap operation. I'll do 2.5 gallons next time (for expansion and evap system) but at 3 gallons that's like 100 more miles a tank which is a lot. Also on dash on first click it hit 323 miles left on tank distance but when i pumped more it didn't go up so that's another reason why I was thinking gm actually did leave 3 gallons more. Book says 12.2 gallons but I'm sure over 15 gallons will go in. I will see on the next tank how much I fill up with (after last bar is gone to full fillup like I did today)
Maybe I'll hit 500 miles this tank. I'll keep you guys updated and THIS IS ALL A TEST I JUST WANT TO GIVE RESULTS FOR EMERGENCY SUTUATIONS.
So far after last bar on gas gauge was gone you can make 25 miles in the city........... now the test is how much can the tank hold after the first click.
