Won't read what codes? Body codes, transmission codes, engine codes? Details man. Lots of details....
Run over something and rip the wiring harness kind of wreck or someone smash the LF corner of the car where the ECM and main harness is kind of wreck?
Airbags pop? Remote keyless entry work? What happens if you try with the key fob remote start? Tried starting with the shifter in neutral? Any other positions to see if the shift cable is out of alignment?
Does the dash indicator properly show the shifter position if you move it to R, N, D or M even when not running?
You hear the fuel pump prime when you turn the ignition on?
Door chime when key is in ignition and door is open?
