1.4L Turbo 2015 - 46k Miles - out of bumper to bumper warranty. No codes
AC stopped blowing cold when my wife was driving home. I checked the car and noticed that the radiator fan refused to turn on
1. Turning defrost, AC HIGH, does not kick the fan on
2. Using a AC manifold gauge the low pressure side is HIGH (gauge goes to max)
3. All j style fuses test fine. I've rotated fuses around just in case
4. All relays have tested fine. I've rotated relays as well.
5. Sending 12V to the fan causes it to run on high.
6. The harness that connects to the fan never shows a voltage
7. The A/C Clutch never engages.
8. Cabin air filter is new
9. Internal blower works
So whats next, Thermostat? My understanding is that I need to replace the entire housing.
Also I'm seeing conflicting guides on the location, is it to the left near the passenger side or to the right near the battery.
Second are Temperature senders. Are there two?
I also see two small relay like devices above the radiator fan, red in color, any idea what these are?
