DevilSonic89
What would be the best flow rate for the 1.8 ???? suggestions pls
about to buy some in like a week
Devilsonic, I know you may be feeling left behind by all the quick power upgrades that all the 1.4T's are getting, but when it comes to adding horses to a naturally aspirated engine, there is no substitute for displacement. And 1.8L is not the best starting point for that quest. Adding hp by getting more flow, i.e. porting heads, bigger cams, higher c/r pistons is an expensive dragon an to chase.
I think you will get more bang for your buck by looking into nitrous, or if you can bear the expense, go the turbo route, but that will be more involved than a simple performance enhancing drug like NoS.
I'll check the average flow rate tonight on my way home
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
