SupaSonic15
I have looked everywhere in the forum and cannot find anyone who has asked this question already so here goes...
My 2015 Sonic has a problem in the afternoons with the A/C. It only blows hot air, even when the compressor is engaged. I hooked my gages up and found the system is NOT low refrigerant, the condenser fans runs, blower fan is on high, temp set to full cold, Max button is in (or out doesn't matter), but air out the ducts is hot. I noticed the high side pressure slowly begins to drop from about 225 to about 150 and the low stays at about 34 the whole time. This only happens in the afternoon when its around 90 out. In the morning the A/C is super cold. Outside temp is about 70.
What would cause the high side to drop and not the low side, and could there be a blend door or sensor going bad that is causing this?
