I have heard several mods off the forums one was a Chevy volt thermo housing mod thought that was elec car ? I guess it has a 176 degree sending unit to turn on the fans ...I am interested since I already had to replace my housing at around 29k miles it cracked and I found out the fan actually has a high speed this summer sitting in a drive through it kicked on high speed at 213 degrees usually it's slow speed on at 209 and off at 198.
Also someone had told me why do you do a solinoid bypass mod ??? All you need to do is turn your wastegate rod 1/4 to 1/2 turn and you will get around 1-3 psi boost increase ...never heard that before .
