Hello I have a 2012 Chevrolet sonic LTZ 1.4 turbo six speed manual. My clutch went out so I replaced it with the clutch set from AutoZone. I install it and blew the clutch, and the car won’t move. You can put it in any gear without the clutch pedal being pressed. Also noticed that clutch pedal doesn’t go up immediately after you release like it’s Stuck. So I took the transmission out again weren’t you don’Stuck. So I took the transmission out and I tried to press in the throat bearing manually and it wouldn’t move. So I replace it with a new clutch set, this time before connecting the hydraulic line to throw out bearing I put the car in gear and started it up to see if the car would move and if clutch works, it moved! So I attach the line and bleed the clutch and same thing. Car won’t move and something is not allowing the clutch to engage
