I suppose this could be a million and one things, plus I'm no mechanic, but I'd like to get some ideas before bringing it to the dealer.
The car
2014 Sonic hatchback, owned since new, 1.4T, 6 speed manual, 89000 miles. Almost always use non-ethanol gas from the same station. In fact the previous several tanks were non-ethanol from the same station.
The situation
I was driving home from a day trip on the interstate using cruise control. It was a warm day, probably upper 90s and reportedly hit 100 in a few places I passed through. I noticed the problem when going up hill. Not an extreme hill, this is an interstate in Florida, but probably required some extra RPM. I haven't done any particular hauling or dusty roads recently. I had my normal load this trip, nothing heavy.
The problem
Engine occasionally sputters. The nearest I can relate is that it felt like water in the fuel. I say this as this turned out to be the problem in a previous vehicle with similar symptoms. I re-fueled along the interstate (89 octane up to 10% ethanol; couldn't find the non-ethanol pump). Problem persisted. Occasionally it sputters so much it disengages the cruise control. I've noticed this at 45mph and 75mph. It usually only lasts a second or two, maybe up to 3 or 4 seconds. But still a hesitation. It doesn't happen on every hill or every increase in RPM.
Other stuff
The check engine light has not come on. It otherwise runs fine. I've not had any problems with this car previous. I monitor the gas mileage and the previous tanks are all as expected, usually around 38-39mpg depending on amount of highway vs city driving. I follow the owner manual schedule for maintenance and do simple stuff myself. Oil changes, spark plugs, etc. I check oil level and tire PSI regularly.
My thoughts
-Wait another tank or two of fuel before taking it in. Maybe it is the fuel.
-It is due for an air filter soon so get that in now, but it just doesn't strike me that this would be the problem all of a sudden. It was on a lawn mower once though.
-Buy a Scangauge or similar to monitor while driving. I'm open to suggestions as exactly what to get and what this will tell me. I already have a code reader but as the check engine light has not appeared I haven't used the code reader.
I'd appreciate any comments. Thank you.
The car
The situation
The problem
Other stuff
My thoughts
