contour24v
I’m working on my nieces 2014 sonic 1.4 turbo. First it was the water outlet easy repair once found once I got it back running the headlights are flickering and the volt meter shows that the current Varies. Battery is at 12.79 volts and at an idle voltage is 13.4 if you touch the gas the voltage jumps up. Headlights and interior lights flicker. I was thinking alternator voltage regulator. Is there anything else I should be looking at? And if it is the alternator I can get the voltage regulator for $27 or whole alternator for $140 any suggestions??
