Sonic Boomer
I know there has been a fair amount of inference that the Sonic will suffer the same type of heat soak that the Cruze has; but does anyone have experience to confirm or refute this?
Yeah, I figured Heat Soak won't be an issue in the next months, but I was hoping some of the people who have had theirs for awhile might have experiences to share. The guy who did track runs in 105°F comes to mind. I know he took measures to cool things back down between the track runs, but his day to day driving may have revealed issues.
Edit: I forgot, he was testing a Cruze:
http://www.sonicownersforum.com/forum/t192/
...nevermind...
Like you said, we'll have to wait for next summer.
I looked at the one on the sedan version yesterday. I will assume they are both the same to keep production costs down. It is a front mount intercooler and looked like a bar and plate. The end tanks were plastic and the charge pipes look like radiator hoses. It could be fairly easily swapped out with another properly sized more efficient intercooler. I don't see heat soak as a huge problem with normal driving. Even the best intercoolers will get heatsoaked eventually if you hot lap them. A meth kit would help with the problem but I don't like how people use them to tune cars to the limit so I am not a big fan of them.
:iagree: its sandwiched between the radiator and the A/C condensor, unless they went with a completely different design from the cruze which i seriously doubt. One design that works reduces cost.
If I remember right it just refers to the intercooler not properly cooling the air because the turbo is so hot that warmer air is being put through the intercooler which causes a loss in power.
I meant that it is not sandwiched on the sedan version of the turbo sonic. It is a true front mount meaning it is mounted in front of all the other cooling apparatus up there. I will assume it is not sandwiched on the hatch version either which is why I said that both designs were probably the same. I was not referencing the cruze. Just wanted to clarify that.
Ok, I'm not sure I follow.
What's cooling the "intercooler" to cool the air?![]()
here is the low tech dirty explanation. After the intake air is compressed in the turbo it comes out considerably hotter than it went in, you plumb it through an intercooler that hopefully stays about the same temperature as the outside air. As the hot air passes through it, the heat is transferred to the aluminum fins on the inside of the intercooler, which pass it to the outside of the intercooler. The air traveling over the face of the intercooler sweeps away the hot air and cools the aluminum. Different intercooler designs have different efficiency ratings which is just a % of how much temperature you can expect to be stripped off the air charge.
for example:
outside air is 100 degrees
enters turbo and comes out 200 degrees
enters intercooler and comes out 130 degrees
the 70 degrees it dropped means that the IC is 70% efficient. (70/100=70%) Air to air IC's can never get the air charge under ambient temps unless they are sprayed with a cooling agent.
pretty over simplified, but thats the general idea.
Ok, so I take it you have two air "intakes".
1) The first intake goes to your engine via the turbocharger, and because of compression it heats and has to go inside an intercooler.
2) This second air intake directs outside air over the outside of the intercooler to take away the heated air that's flowing through the inside of the intercooler. Kind of like a reversed heat exchanger.
Then I take it there is an induction fan on the second air intake in order to keep the cooler air flowing over the intercooler at all times (especially when stuck in hot city traffic)?
well take a pic of that thing.. this is an interesting development for the cruze if the sonic is using an intercooler that is actually mounted in the front instead of between the condenser and the radiator. I have yet to see a 1.4 here in central arkansas or in memphis when i went over there last thurs., only 1.8's.
I should have taken a picture at the dealership but I know turbo cars pretty well and it has a front mount. The core is about 1.5" -2" x 3.5" - 4" x about 24" or so with plastic end tanks.
