So I finally went to perform the bypass valve mod and immediately broke the fitting/barb on the bottom of the passenger side of the intake manifold....
I was wondering if I could route the line from the vacuum canister at the bottom of the IM to the BPV and JB weld the port I broke shut? I'm referring to the vacuum line on the left of this image at the bottom of the IM.
I just pulled the hose on the canister off of the bottom of the IM and it make a hiss as if there were still vacuum in there.... I'm concerned the canister is switched in some way which might mean it's not fit for being connected to the BPV.
JB welding the bottom left barb I broke back on seems like it won't be reliable... I'd like to JB weld it shut and find another vacuum source if possible.
Can anyone help?
Can anyone help?
